I have only the basement with radiant. It's a slow gentle heat. If I put the radiant on, 70 say- the main floor gets there slowly. It doesn't go crazy in the basement. With the basement door open it balanced faster, but not much. Mind you I ended up with three heat sources. The woodstove, and two Mitsubishi ductless: one in the kitchen on main floor and one in the upstairs master. I got them mostly for the AC, but they heat the place fast.
So let's say I keep the radiant at 58 when I'm gone for a week. I come in, hit the two ductless to 68, hit the radiant to 70, and start the woodstove.
Within 20 minutes the ductless cut off bc the woodstove is rocking. The basement has come up to 65, and gets to 70 in another hour.
Woodstove becomes the only thing running fast. I get a 12 hour burn if I pack it...
If I sleep in and the stove is cold, the radiant will have kicked back on and the whole place is toasty...
Ok there's my radiant situation over explained...
