Results 1 to 1 of 1
Thread: IBC Tote approved alternative septic, code compliant(ymmv)
    3,767
    124
    One of the more interesting items that I've seen on FB Marketplace.
    A code compliant, above grade, IBC tote based septic system.
    https://www.facebook.com/marketplace...3029644231072/
    City Compliant 330 Gallon Compost Processor IBC Tote
    Portland Oregon
    Here is a composter/'composting processor' made from a 330 gallon IBC tote steel pallet container, with a discharge valve at the bottom. It was used by the last occupants of my house, who had a city approved composting toilet. Though I wasn’t as good of a person and switched to a normal toilet.
    It was previously approved by the city for human waste, and compliant with the IAPMO (international association of plumbing and mechanical officials) / ANSI Water Efficiency and Sanitation Standard. I assume you'd have to go through the same process to get it approved for this use at any other address (talk to the city). But it's great for food/yard waste composting as well. It has a ventilation/aeration system built in (see photos).
    Attached Images Attached Images
