Results 1 to 23 of 23
Thread: Need some advice on yellow blisters in our cabin chink
    I have developed some bright yellow blisters in our cabin chink. Anyone know what these might be caused by? Any thoughts on repairing and remediating? Thanks a ton.
    Here are the pics:
    https://ibb.co/D9hwzv5
    https://ibb.co/NShWKk0
    https://ibb.co/FzFTm9S
    https://ibb.co/fYPP1JN
    I’ll try and upload them.
    Yep...didn’t work, but those links will take you to the ImgBB page where they are hosted at. It’s a free image hosting service.
    5,432
    That looks a lot like expanding foam.....
    Are you saying that this magically appeared on its own?
    Completed #1 - Sold #1.....#2 finished and moved in
    14,760
    My guess too. Did you build it or someone else?
    It looks like it was chinked with Permachink on one side, then spray foamed from the other side before Chinking the other side.
    Just my guess.
    Sent from my Pixel 3a XL using Tapatalk
    4,143
    Looks like spray foam, but also looks like it might be mold. Can you scrape it off?
    Just acquired a property with a cabin guest house. Never really inspected the cabin until we took ownership. Frankly, I don’t even know how old it is. It’s quite small, and did not offer much to enhance the value of the property itself. Now my wife wants to “fix it up” and in the course of looking it over, I noticed these blisters. I tried a Google search and came up empty. I figured I would try and find some experts to assist my efforts. I hope this extra info lends context.
    5,204
    Looks like aerosol spray foam. Scrape some off, should be dry.
    Quote Originally Posted by allen84 View Post
    Heading back to the property early this week. What would they have used yellow spray foam insulation for in so many different places? And why not simply use white?
    14,760
    Have you ever seen white foam insulation?
    5,432
    Probably trying to seal cracks (improperly), and the yellow stuff is commonly sold at the big box stores.
    5,204
    Quote Originally Posted by Cadster View Post
    Those are hand hewn logs, it's likely pretty old and possibly was dismantled and rebuilt at some point. Let's see more pics, of the outside, as a whole... That's where the real problems can start.
    Yeah, appears to be spray foam, and here's what probably happened. Like Allen said, the place has been rechinked. They probably did it during a cooler time of the year. They probably filled any gaps with foam, and almost immediately went over it with Permachink. The problem with this is, the cold really slows down the expansion process, and sealing it in with the Permachink slows the solvent evaporation that cures the foam. What you get is foam expanding after the chinking was applied, and squeezes out from every possible avenue. The good news is, if it is spray foam, you can just quickly go over it with a wire brush, and may not even need to touch up the Permachink. If it's some other type of sealant, particularly some type of non-curing variety, (butyl rubber for example) you'll have to cut out the Permachink and redo.
    So the cabin was built in 1991. Here are some exterior pics. Not sure how old the logs are, or if they were taken off a different structure before fitting them to this structure.
    https://ibb.co/2v4HLVb
    https://ibb.co/hVFJDFX
    https://ibb.co/FxhmLgG
    5,204
    If that's the guest house you never really inspected, you must have bought a real nice place!
    what he said!
    what he said!
    Yes...the place is nice for sure. It will be our primary residence and this cabin is a cool, if quirky, little feature. It certainly added value to the property for us, but for many others, maybe not so much, as most people would probably prefer NOT to have a cabin in their backyard (at least that is what the realtor said might account for the long sales cycle). That said, we’re delighted.
    Thanks everyone for kindly taking time to share with me your feedback on those yellow bubbles. I’ll come back to the board and let everyone know how it works out after we repair those areas. We’re also going to retreat the exterior, as you can see in the pictures, the logs need some love and maintenance.
    Looks like the deck needs more attention than the walls, but always good to stay on top of the maintenance, rather than wait until it's way overdue.
    5,204
    Potential problem areas are wood nearest the ground on the sides that don't have much roof overhang. Depending on your climate, you probably have nothing to worry about, just do as much as you can to keep water and moisture away. And you have copper gutters even LHN should be jealous of.
    Nov 2010
    Columbia, MO
    1,804
    Looks like a great place for a little front porch sittin.
    https://daleslogcabin.shutterfly.com/
    3146 kilometers away from Loghousenut
  22. #22
    Hello to All
    I am searching on how the logs keep together? could anyone explain me how to make all the logs tight together? what kind of screw do you guys use to stick logs on top of each other?
    Thanks in advance
  23. #23
    5,432
    Quote Originally Posted by Reza View Post
    Hello to All
    Thanks in advance
    Hi, sounds like you need to sign up for the class!
    Sent from my SM-G991U using Tapatalk
