Results 1 to 2 of 2
Thread: Synthetic chinking versus mortar chinking
    3,741
    100
    Can you imagine how much time a person saves using synthetic chinking?
    I'm trying to wrap my head around the theoretical math.
    Mortar chinking:
    Shove in backer rod / insulation.
    Hammer in a 'few' nails.
    Order sand, lime, get a mixer, hawk, trowels, cleaning supplies, spray bottles, sponges, et cetera.
    Mix a a cubic foot or two of mortar and start troweling it on.
    Walk back a few times to refill your bucket and/or hawk (eventually ladders are involved).
    Keep mixing small batches and keep walking / climbing.
    Synthetic chinking:
    Shove in backer rod.
    Rent a chink pump with a 25' hose.
    Buy a bunch of synthetic mortar in buckets and dump'em in the hopper.
    Chink away with the press of a button.
    Keep dumping buckets into the hopper as needed, and keep using the 25' hose to apply.
    Sure there's a cost difference between mortar chinking and $ynthetic. Material and a pump rental.
    Yes, the synthetic can trap more moisture behind it on a seasonal basis, thus can cause rot issues.
    Yes, the synthetic can blister and separate, and generally has a 20 year lifespan.
    Yes, the synthetic is more of a non-natural material with the accompany off-gassing of chemicals.
    Yes, the synthetic can be lit on fire and does emit smoke.
    But, it sure saves a lot of time if you're simply building a new home and want to move in quick.
    5,430
    The cost difference would be huge.
    Unless you fill the gaps with a rigid foam, then a skim coat of synthetic over it?
    jandjloghome.blogspot.com
    Completed #1 - Sold #1.....#2 finished and moved in
