We discussed this briefly on the last zoom and it seems the more I look into setting posts the more options, “new and best way”, sales pitch or something to sell.
For the last 100 years posts have been set in the ground and backfilled with dirt tamping your way up. When I took down my great grandpa’s tobacco barn a couple years ago not a single post was in the ground. It was either sitting up on cobblestones or nailed down to another timber. Yes it had some rot but had been standing almost 75 years and broke a rope several times and fought us all the way to the last pull with a truck and still came down only in sections at a time. Now there is….just to name a few….
1. Set post in hole and backfill with dirt.
2. Set post in hole and backfill with concrete.
3. Put gravel in bottom of hole then backfill with concrete and dirt
4. Put concrete in bottom of hole backfill with concrete and dirt.
5. Put concrete cookie in bottom of hole and backfill with concrete and dirt.
6. Use a plastic sleeve around the post and backfill with concrete and/or dirt
7. Use expanding foam in the hole around
post.
8. Pour in sonotubes and wet set brackets from the cheap ones to the expensive permacolumn ones.
9. Pour in sonotubes and use L brackets to top surface mount posts…..
So what say Ye? I know code requires different things in different parts of the country, but if you were not getting it inspected what would be your favorite and preferred way of setting a post for a shop or barn all things considered for both strength and longevity.
Sent from my iPhone using Tapatalk
