Originally Posted by
dvb
They are definitely covering a gap with that chinking, I think the question is are they covering a problem? I believe that if this vertical support is stable you are OK. Did you try to shake the log to see if it was loose? If it is loose, maybe all you need to do is lift the log into place by adjusting at the lower end. Does the support log connect to anything else other than the two ends shown? If it does you may consider what effect that would have on that point. Typical kit log house problem with the need to adjust everything as the log shrink.
