I'm not teaching the class via forum threads.
This forum section wasn't really intended for that.
It was intended more for general questions about the process and specific questions about areas of concerns (i.e. why the heck doesn't it settle?! You guys are lying!).
In 2 months or less there should be a very easy way for the LHBA to assist you. If that's not fast enough, then...
If you watch every youytube video, and read every link here:
https://community.loghomebuilders.or...-links-allowed
And take really good notes, then you can probably figure out enough to make it work asap (figure a month of research and note taking).
There's also that book you ordered.
As Skip Ellsworth used to say, "With the Butt and Pass method, you can screw up almost every other step in the process and still get a solid home in the end."
But I respectfully suggest that in 2 months or less there should be a very easy way for the LHBA to assist you via an online course that lasts approximately 22 hours.
It might be the easiest path for you -- and the least expensive option possible (if only because it will save you money in so many ways).
