Results 1 to 3 of 3
Thread: Electric rail bike
    Administrator Ellsworth's Avatar
    3,664
    78
    Electric rail bike
    This thing is amazing:
    https://youtu.be/R_JyDOIWHQk?t=313
    Why in the political section?
    Take a guess!
    Why not in the public area?
    Take a guess!
    But seriously. I like the concept of rail carts / bikes.
    edited to add:
    https://www.youtube.com/watch?v=NZXf3SVcoao
    Close up of his modifications.
    Paraphrase "It's easier to commute across town on the rails compared to the road."
    [jokes about a quick get away after the next Presidential election aside (regardless of which side wins) this thread was moved from Politics area to General Hobby, because it's a neat hobby)
    5,420
    That's pretty cool.
    I ran into an older guy in Butte one time with a similar, non electric version of that.
    jandjloghome.blogspot.com
    Completed #1 - Sold #1.....#2 finished and moved in
    3,664
    78
    https://www.trains.com/trn/railroads...of-separation/
    Railroad track is 4' 8.5" wide.
    I had no idea.
    I wonder what minimum flange height is for wheels?
    Edited to add:
    "Flange height. Wheels and tires
    may not have a flange height of less
    than 1 inch nor more than 1.5 inches"
    https://www.govinfo.gov/content/pkg/...sec230-112.pdf
    Edited to add:
    https://www.youtube.com/watch?v=iFGExND7cqo
    That seems cheap and easy to make.
    I like his wheel choice for the quieter factor.
    The wheels off a 55 gallon barrel hand truck might work great (approx 10" diam, solid rubber over steel).
    https://i.ebayimg.com/images/g/yv8AA...Nk/s-l1200.jpg
    Find the right deal and it's $100 for 4 wheels and most of the steel you need.
    A rail cart like that would take access to some abandoned lines known to be unobstructed, it'd be heavy.
    https://www.youtube.com/shorts/SoX_2b9T3Ow
    https://youtu.be/77dY8i5NqGM?t=104
    Seat(s) that swivel 180 degrees and controls that work when the seat is facing either direction!
    No need to rotate the cart.
    Amazing enthusiasm...
    https://www.youtube.com/watch?v=SAYS1JRVehc
    Simplicity and triangles...
    https://www.youtube.com/watch?v=zc4EGXptqi0
    Bicycle built for two...
    https://www.youtube.com/watch?v=J0NVbiulPDY
    Bosch tubing, solid build?
    https://www.youtube.com/watch?v=ssfRs4SkqUs
    How about with an electric scooter?
    https://www.youtube.com/watch?v=DocKkrgarDo
    13 mile range, it would need an auxiliary battery under that luggage rack...
    Columbia rail taxi, motorcycle and plywood...
    https://www.youtube.com/watch?v=oKeW355u4Do
    When things go wrong...
    How did they get home?
    https://youtu.be/stsGKb_KMmM?t=489
    Full face helmet!
    https://youtu.be/0v3dK13rsSo?t=135
    Weight distribution issue? (Caused by engine weight over rear wheel?)
    https://youtu.be/0v3dK13rsSo?t=340
    A bike mechanic explains the world...
    https://www.youtube.com/watch?v=lJxxph5pQEg
