Good luck with your class and new home
Hey edkemper
Good to know that there are people close by who are also dreaming about log home.
I am sure it is worth while to take the class. Its a great skill to know.
I am reading all the posts here and preparing mentally for the big task. Good luck with your class. I have read that the member group is like a family. People help each other and you can rely on people.
Will join the member club someday soon.
Feasibility of a log home
Shank,
It is very feasible! It will require lots of hard work, patience and planning but it's definitely possible. It's all about time and money. If you have plenty of one you don't need a lot of the other. Take a look at this article which explains this theory much better than I can. http://www.loghomebuilders.org/how-build-log-homes-rich-dad-poor-dad-method
My best advice, other than to read everything on this site, is to take the class to learn all about the possibilities of this building system. Welcome to the forum.
JD
New User from the Black Hills
Its my first forum being a part of, I seem to read a lot of them on this site. Lots of good info. More the less Im fro the Black Hills of SD. I used to cut a lot of pine beetle trees down for people and usually just bucked them into firewood. They are PP and always have a sweep in them. I started keeping some of the logs and built stick frame house using the logs for deck uprights, hand rails, corner wraps, etc. Mostly just accent stuff with that turned out really cool. What I have been wanting to do for as long as I can remember was to build a log cabin/house. This is now my plan, got a spot picked out and have been reasearching different techniques and designs. I wont do a kit, not that I am against them but seems to not be for me. I am planning on doing this for a very minimal cost and time considered and tools needed for other scribed methods, that is why I like this method and I like the look when its done and size of the logs used my R-value should be pretty high compared to the kit stuff. I also plan on using a lot of recycled materials and obtaining a roughcut saw, but know a guy that can mill me boards when needed. I plan on doing a small log house 700sq ft with a loft/bedroom up with battens and stick frame 2nd level. I think that using PP Im going to have a lot more short sections due to the sweeps in the logs, so my question is to use this style of construction what would be the proper way to hold the logs together in the middle of a run, or do I need to just have longer logs? Can I leave a little sweep in them and if so how much. What tools should I start aquiring that I can possibly find used. Lots of questions which Im sure I'll get out there at a later time. Roof system engineering, tricks, suggestions to make learning a little easier. I'm a trail and error guy but always listen to suggestions. Have a good one.
Oh right.. I re read it and
Oh right.. I re read it and still assumed that it was clear and understandable.
OK start again ...
I'm from the UK living on the outskirts of Calgary Alberta Canada and would like to move to British Columbia Canada.
I'm not sure I agree with you on the equity thing though The market is different here in Alberta to the states and seems to go cycles. Also we are in the process of doing a few upgrades as well as getting the mortgage down as much as possible which in turn will increase our equity.
Sharing costs for the Feb 28th class
I'm Keith from way down in Lafayette, LA.
I just retired as of Jan 2nd.
Looking forward to attending the Feb 28th class.
Would like to make contact with other attendees prior to the class. I'll be flying in to SEA on Friday the 27th and will be renting a car. Am looking for one or two others to share transportation costs and possibly lodging. Haven't made sleeping arrangements yet, but would like to share room costs if a room with two beds is available (maybe even at Walace Falls Lodge?).
email me at KeithDupl@aol.com
Just got home from this weekend's seminar
If you haven't already attended the class, you must. I got enough before lunch on Saturday to more than cover the cost. I drove 1000 miles in two 10 hour days (thanks to weather) to get there and it was worth every mile and hour. Then I had to drive home 800 miles while looking at everything differently. From the logging trucks in Washington and Oregon to the number of corners in any particular house along the way home. It'll take a few days to empty enough of what I learned to let the rest soak in. Damn that was fun and full of help.
Welcome EdKemper!
Wow, you
Welcome EdKemper!
Wow, you did some driving. I am glad you took the class.
Your life will never be the same. :)
Kola
Any one can build these homes
Inga,
Getting land with trees on it does cut down on cost to build.
And allot other things add up. Does the land perk for septic.
Mine dosent so it cost me some more but i got my land cheep for my area and thats why.
If you want to build it and are not the kinda person to give up easy you could build it. And if there hard parts you can always find help from friends and family.
It all comes down how bad do you want to build it.
My property is at slant little harder to work then buying flat land. But i am in the mountains were a log home fits in.
Inga read all what the site has to offer and see if it for you.
Nothing in life is easy that you relay want becuse your gone have to work for it.
looking forward to Feb class
Hi, I'm Yob from south korea. I'll be flying in with my wife for the upcoming class. I first found the LHBA website several years ago, but finally I'm going!
Because it is not easy to cross the Pacific often, I would love to see and learn as much as I can in everything about building a log home and other forms of natural building, such as cob and roundwood construction. So I plan to visit owner-built homes around the area (Pacific Northwest and even perhaps So Cal) before heading back home in mid-March. Can any of you suggest anything I can do to do this? Any word of advice would be very much appreciated. Thank you!
