building your own log home
yes welcome:) you can definitely do this yourself! take the class and read all you can in this forum. there's a lot of good info here.
Sounds like you have very
Sounds like you have very realistic ambitions. Can you do it yourself? Well, that depends a lot on yourself, but if you know which end of a hammer to use, I think you'll be able to handle it. Much of it is simply common sense. Like, "how tall should my trees be?" Answer being, "At least as tall as your wall is long." But the better answer is, "The bigger, the better." No doubt, there will be times where problem solving skills will be put to the test. Just ask ClaireNJ ;-)
Of course, I'll echo the all too good advice given so far, take the class. It really is worth it.
