Advice needed..... desperately
Well my mother is interested in a log home, however she wants a log home kit. She's convinced that it will be faster, than building one ourselves. I am not convinced of this, myself. What I'm asking for is ALL the advice you good people could provide me.
Thanks
Question 1. Is there a site I could go to, to look up log prices?
Question 2. Approximately how much would it cost to build a 1500- 2000 sq ft two story log home?
(just looking for a ballpark estimate)
Question 3. How much less would it cost to built it a single story?
Question 4. Approximately how long would it take to build a 1500-2000 sq ft one or two story log home?
( again, just looking for a ballpark estimate)
Question 5. Is there any useful information you can think of, that I've not asked for?
People just do not seem to
People just do not seem to realize that costing out the building of a home is an extremely variable calculation.
You can build a 2000 sq ft home for $100K (excluding land cost) or you can spend $500,00.
You can spend $2,000 to have plans drawn by a designer or spend $30,000 to have plans drawn by an architect.
You can spend $0 to be your own General Contractor or you can spend $60,000 to have a General Contractor
You can spend $10,000 on a kitchen that has very nice cabinetry or you can spend $60,000 on custom cherry cabinetry.
You can spend $5.000 on laminate flooring or $50,000 on exotic hardwood flooring.
Here's the real bottomline. The outside walls, framing and roof is relatively inexpensive. Doesn't matter if you are using logs, 2x4's, Sips, ICFs or whatever. The real expensive costs start adding up when labour costs get factored in. Labour costs are the real killer. The more you can do yourself (sweat equity), the lower your house cost will be. Example, you can get very nice hardwood flooring for $4/sqft but it costs $7/sqft to have it installed (thats $14,000 labour on 2000 sq ft). It can cost $500 in paint to paint the inside but it would cost $5,000 to have a painter do it. Framing/floor/roof lumber may cost $10,000 but the labour will cost $20,000. So, you get the idea. But the highest cost is the interior fit&finish. You can spend $1000 on a kitchen faucet or $150. Trim carpenters are very expensive. The trim around doors, basetrim, crown moulding, etc is very labour expensive. Having said that, it would be well advisable to have several skilled trades do the work rathur than DIY.......like electrical or plumbing or septic. But even here you can save money. Having the electrician install just the panel and wiring and you install the switches, recepticles, light fixtures will save you good coin. It all depends on how much work you are skilled enough to do.
Log home kits. Problem here is that you are paying the labour costs. You are paying the labour for the kit company to put the kit together (plus their markup). Then you pay labour to have the kit erected on your site. Even if you erect the kit yourself, you've still paid the labour and markup of the kit company.
If you have a source for raw logs, and the time and patience to process logs yourself (peel, dry, etc) then you can save money. But not everyone has source of logs. Not that easy to get logs. You may have a couple of acres of land outside of a city and there may not be any useable trees on the land. You could look at buying milled logs (air-dried or kiln dried) at substancially less money than a kit. You put the walls up yourself, cutout your own window and door openings and save a ton of coin. You've just by-passed the kit companies labour and markup. Of course, knowledge is power and one needs to educate themselves on building with logs......real logs or milled logs....the principles are basically the same.
Thanks for the information,
Thanks for the information, it has helped.
I'm eagerly anticipating the next log home building class. Hope I can get in.
I have a little bit of experience in building traditional stick structures, so I'm not completely lost. :)
I thought of some more questions, and I thank you for your advice, and patience.
1. I've heard of kiln dried logs, are these good, and where would one find them?
2. Are they worth the price?
3. Do you think three strong men could build a 1500-2000 sq ft log home in 9 weeks or less?
Thank you.
Tommygun, Kiln dried logs
Tommygun,
Kiln dried logs and price...You may have seen me post a similar answer on another post today but before you start thinking to much about plans and materials my recommendation is to take the class. Your concept on building and materials will change!
9 weeks...this is a very open ended question and is asked quite often on the forum and it always gets the same answer. Are you working full time/part time? What type of equipment will you have available? What type of site are you building on? How well have you planned the building stages? Will the weather cooperate? No one can answer this question because everyone and every situation is different.
IMO...If my brother and me were working full time on a log home for 3 weeks with an ideal site and good weather and most of all KEPT IT SIMPLE, yes we could have the shell up.
Costing-out is always good
Costing-out is always good practice, but one should keep in mind that many of us look to "never pay retail, let alone wholesale." Materials figure differently in our cost analysis. My own costs are at odds with what most professional builders would even consider, as they are not gleaned from the run of the mill timber end-products they are acustomed to. Kit manufacurers suffer from the same "limited market" mindset.
One analogy would be a professional costing fuel for commercial fleets and a home owner costing their bio-fuel. They are actually using two separate markets that have some overlap, but yet are very unique. You can bet that the professional will almost always err on the side of the "status quo market mindset.' The home owner does not have to--and should not as there are always alternative sources for materials.
Labour can be the short way to savings, but materials and good planing are where you can get at the real bargains.
In best practice, you do both---your own labour and strategic materials sourcing.
In my opinion, the only way that "turn-around time" should facture into it is if you truly have a unique need for a structure to be up and usable in a specific time frame. Usually, those "special circumstances" already carry with them their own mental/financial drain. If "convinience" is the reason, then a prospective builder should sit down and take a long hard look at their abilities, what they are willing to pay for and how much motivation and patience they have.
Why be in a hurry to spend all your hard earned money in the shortest amount of time possible?
Take the class and I will bet that you start thinking about time differently.
-Andrew
tommygun-- your questions
tommygun,
regarding your questions about kiln-dried logs:
one thing i like about this building method is that you can build with green logs. no worries about "seasoning" your logs, or kiln-drying, if you don't want to.
as to the 9-week time frame, it' been known to happen. read this:
http://www.loghomebuilders.org/9-week-log-home-0
2 cents
Thanks for all the useful
Thanks for all the useful info.
I do plan to take the class, however, there is not one scheduled at this time.
I'm trying to get an idea of what to expect when I do build. Currently this log home project, isn't mine. It's for my mother, and she wants it done this year. This is kinda a spur of the moment thing.
I was under the impression that you had to use dried logs in building. If one uses "green" logs, wont they split and crack when they dry?
I live in the KC Mo area, and all the trees here are not good, any suggestions on where to look, or whom to talk to for good logs?
I thank you all for your advice, and information.
