I've seen a lot of pictures of hammers used to drive the rebar. What hammers are recommended by people that have actually used them? If you can be specific with model number, that would be great.
I had one shop recommend a Bosch 11247 Rotary Hammer which is 10 amp and 5.2 lbs impact energy. Just not sure that is big enough, but anything would be better than swinging a sledge.
Also - what about drills recommended? I thought a rotary Hammer drill would also drill, but it isn't rated to drill in wood, only concrete. Is the Milwaukee Hole Hawg a big enough drill for the job.
