A few thoughts about peeling bark from Douglas Fir (also Hemlock and White or Noble Fir). Other logs may be different.
I have a real problem with how we talk about cambium layer and the like... I was taught in biology about the xylem and phloem cells that make up the layer of Cambium Cells... The Xylem cells make the woody layers that are more or less dense which make the yearly rings... OK then, I got that off my chest. See below.
I have been taught that the annual layers help shed moisture hence it is good to just remove the bark and keep the ring structures intact. The easiest way to do that, IMHO is with a spud or scraper that rides along the sapwood and leavers the bark (phloem) off... You are then left with ( in Douglas Fir) a dark streaky dirty layer of stuff that can look quite attractive sometimes.
If you want to remove the streaky stuff you can use a power washer with out tearing the fibers of the heart or sap wood. It can be easily done because I have done it. Check out any of my logs.
One thing about peeling logs from an ergonomic perspective is that the leverage from a long handled spud is really important. Note; the spud in the picture is the original Blue Wonder, the perfect spud.
http://i154.photobucket.com/albums/s...1/IMG_2573.jpg
The reason you want to power wash the logs on the ground is because you want to put up clean logs and not need to power wash both inside and out like the below picture.
http://i154.photobucket.com/albums/s...1/100_4087.jpg
About logs that has been peeled with a draw knife. They look like this - you can see different annual rings. some folk like it... I don't care for it... But that's just me...
http://i154.photobucket.com/albums/s...f/100_0256.jpg
Below is taken from the Encyclopędia Britannica.
"cambium, plural Cambiums, or Cambia, in plants, layer of actively dividing cells between xylem (wood) and phloem (bast) tissues that is responsible for the secondary growth of stems and roots (secondary growth occurs after the first season and results in increase in thickness). Theoretically, the cambium is a single layer of cells, called initial cells; practically, it is difficult to distinguish the initials from their still-undifferentiated daughter cells, and several cell layers are collectively called the cambium, or cambial zone. Cambial cells divide to produce secondary xylem cells toward the central axis of the stem and secondary phloem cells toward the outside. The cambium originates from undifferentiated cells that have retained their embryonic capacity for continued growth and differentiation."
