Squaring off logs
I read in the FAQs that there are to many reasons why squaring off the top and bottom of the logs is not a good idea. Can anyone explain why?
I am planning on doing just that and have recently designed an built a chainsaw mill for that purpose. My intent is to square three sides of the logs.
How big of a cabin do you
How big of a cabin do you plan to build?
I'm curious about your chainsaw mill, is it based off the procut plans? Could you post some pictures?
Class
I would love to! I have realized very quickly that I have a lot to learn but I just can't make it right now vegas is a long way for me. We just had a baby so money is tight. Hopefully soon.
Chain saw Mill
I'm not sure yet on how big I'm going to build I'm still trying to figure out the ins and outs of this craft. The more I look it seems the more I need to learn! My back ground is mechanical so I'm more into working with steel than wood.
As far as the mill goes I have looked at many styles procut being one of them. If I had to compare it it's more like the logosol M-7 with some improvements. My biggest concerns were Accuracy, length of cut, and comfort. I just cut my first log with it last weekend and I and please to say that I think I have accomplished my goals. As far as accuracy it cuts a perfect 90 degree angle the length of the log, which can be up to 22 - 23 feet long. I can't get over the quality of the cut, I am using my standard crosscut chain and it works fine. I cut three sides of a cedar log in less than five minutes. I'll be playing with it this weekend so I'll take some pictures and post them.
One of the reasons is
One of the reasons is because when you cut into a log to flatten it, you are removing the natural layers of the log that protect it. Additionally, when you have flat on flat sections of log, moisture will want to wick into that joint & could cause issues.
If you are planning to build a log structure, I'd suggest taking the class if you can. It will save you alot of money in the long run.
I concur...
Go out in the scrap pile and find two pieces of lumber that have been sitting since the last rain with thier flat sides together. Notice that they are wet when you pull them apart. Also notice the stuff that is growing in between them. That's the tuff that tries to eat milled log houses for lunch. Any moisture that hits the crack wants to migrate in to where the fungus wants to grow.
Take the class. With a name like yours you'll fit right in and you'll be an easy convert.
Thanks guys! I'm glad I
Thanks guys! I'm glad I asked. I would love to take the class hopefully they have one in the northeast. It seems like you have a good group of enthusiasts here.
Yes, we have alot of great
Yes, we have alot of great folks around here, & especially on the member's side.
I took the class in 2006 & we've been in our place for over a year now. Absolutely wonderful.
Professional Engineer
D-Logs
There are designs out there for D-Logs with 3 sides flat but one thing you always want to be careful about is mixing methods. The people I have known who have made their own D-logs or used just flat sections mated have problems sealing between the logs to keep them air tight. That's where some people get the idea log homes tend to be cold. The LHBA method uses rebar to connect the logs which limits settling but as you logs shrink or expand the gap between the logs changes. There is rolled up insulation between the logs behind the chinking to fill this void as the logs expand and contract to keep the system tight for air infiltration. Some D-log designs use spikes or lag bolts about every 24". The ones that work best tend to overdrill the connector in the upper log so the spikes or screws don't hold the logs apart as they expand and contract and you don't change the gap but your whole wall will settle as your logs dry out and depending on your climate there will be season expansion and contraction of the log wall.
Of course as pointed out, you then have to have a method to deal with any moisture intrusion. Whatever system you use, you have to research and look closely at to make sure all aspects are thought through. That's why there are many different building systems for log homes each with their own unique problems. If you follow the LHBA system as taught in the class, most of these problems have been well thought through. If you start changing any of the systems and doing your own thing, you have to think through all the possible problems you may be causing or live with them when they occur. Good Luck.
D logs
Thanks Richard, My plan was to mill a groove in the center of the log and use spray foam to seal the logs, Then screw them down. I've been looking for a fungal treatment without much luck so far. To deal with the water intrusion I was thinking a wrap around porch and really big overhangs to keep the rain off. I am fortunate, I have the trees on my property so I should be able to compensate with adding roof size. Which brings me to my next question, What is better? I have white cedar and spruce trees to choose from. Any suggestions there?
Thanks Neil
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
