Originally Posted by
rreidnauer
Well, you already called it ccosborne3. Doesn't matter what structure you build, log, adobe, cement, whatever, if you can't get to water, you can't survive. It's consideration number one when it comes to deciding on whether to buy a piece of property or not. As for the effects on logs themselves in a desert, I'd imagine intense UV energy on exposed wood may have some detrimental effects, but even so, I'd also expect it would be far less than moisture related problems. The thermal mass of logs would help greatly in the temperature extremes of a desert too. Not as good as a thick adobe building would have, but quite good none-the-less.
I think the primary reason you don't see log homes in the Arizona deserts is simply a case of they don't fit in with their surroundings. Adobe and masonry is the style for the deserts, just as Cape Cods are to New England. This is not to say you shouldn't build one there. I've always went on the premise that just because everyone else is doing something, doesn't mean that I have to as well.
