Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: White Pine Log Prices
    I saw a local ad for 40' eastern white pine logs (anywhere from 12" to 18" in diameter) that I would have to cut down myself. The guy wants me to make an offer, what are they worth per log?
    Thanks, Christopher
    2,493
    $/log
    Logs are usually priced at $/MBF (thousand board feet). out west we use scribner scales to determine the volume of wood in a tree. Find out how much a local mill pays per thousand, and subtract off how much you will need to pay to get them transported. Subtract off how much you'll pay a logger to clear the trees, since logging is dangerous work. Even if you have the safety equipment/saws and feel comfortable doing it yourself, pay yourself this amount.
    That would be a place to start.
    LHBA Member Upers's Avatar
    Aug 2006
    Chicago/UP Michigan
    411
    White Pine Logs
    Christopher,
    I have seen these same types of logs go from $70 to over $300 in my many many months of research (lots of comments on this fourm)...
    I am currently days away from hand picking my live trees to be cut down from a logger for around $200
    I think I can get lower, and the logger comment to me was that he can't get $100 for them from the mill
    Also the logger said he has to give the land owner half the $ he gets for the log
    So start at $50 per log and see what they say!
    Also, ask how many they have - I am in Chicago, but building in the UP of Michigan - so I would really like to know.
    Yoopers Pat
    Paradise Valley, Montana
    740
    If you have to cut and buck them, I would offer him 20 a tree.
    Is the entire tree 40 feet or is that the usable length?
    Patrick
    Ragdump People in Northern
    Ragdump
    People in Northern California that had fire killed trees were getting little or nothing for them ,they were lucky if loggers would come in and cut them
    9,298
    I'm with Patrick. If you're
    I'm with Patrick. If you're doing the work, I'd offer $25 a stick. Doesn't sound like much until you add up how many you're taking, so don't offer a "per tree" price, talk total, like $2500 for 100 trees.
    Thanks
    Thanks everyone for your replies.
    It is a local farmer that planted a bunch of trees 45 years ago as a wind break for is house, so I think he only wants to get rid of 10 to 17 of them but I'll let you know if I come across anymore for sale. I?m not sure how much is usable ? I haven?t seen a photo or anything. If I decide to get them I?ll try offering him 25-$50, my only problem is hauling them, do you think I could haul a 40' log on a 18' car trailer? And if so, how many per load?
    9,298
    How far do you got to move
    How far do you got to move them? Do you have to go on any main roads?
    I have thought about this situation myself, where, if I can find logs close to my property, I may move them myself one to three at a time. I could throw together a pole trailer like the power companies use pretty quick, using the rear portion of an old pickup. I'd just have to find some material to make a 30 foot tongue.
    One wet 40' log is going to be pretty heavy, so moving one at a time is probably best with whatever you'll be towing with.
    logs on a car trailer
    Quote Originally Posted by Timberline
    Ragdump
    This is what a 40 ft.log looks like on a 26 ft. car trailer
    Ragdump The other problem
    Ragdump
    The other problem is lifting the logs , green logs that size probably weigh somewhere around 2000 lbs and the big one one my trailer was closer to 3000 lbs
  1. white cedar vs white pine half-log siding
    By oldblue in forum General discussion about log homes and cabins
    Last Post: 09-29-2006, 04:17 AM
  2. Black Spruce, Red Pine or White Pine?
    By baspuit in forum General discussion about log homes and cabins
    Last Post: 09-30-2005, 02:59 AM
