Page 17 of 17 FirstFirst ... 7151617
Results 161 to 166 of 166
Thread: Wind power
  1. #161
    Stator mold construction
    The stator mold is pretty straight forward compared to everything mentioned previously. Size is simple to determine. The inside opening needs to be large enough to allow the rotor threaded rods to pass through, and the outside diameter needs to be large enough to allow drilling mounting holes in it, outside the area where the coils are embedded. Meanwhile, thickness is determined by the coils themselves, only making the stator slightly thicker than the coils themselves.
    I just picked up a three 2'x2' pieces of particle-board for my mold, at the local big-box store, to build up a three layer sandwich. The top and bottom layers don't involve much work, but the middle layer does get significant modifications. OK, to each their own, the following is how I made mine. If you come up with another way to achieve similar results at reduced costs, great!
    I found center of one of the boards, and took a makeshift circle compass to mark both the inside and outside diameters of where I was going to need to remove material for the coils. I then laid that piece on top of one of the other boards. I screwed the top board to the bottom board (countersinking the heads) and careful NOT to put any screws where I needed to remove material. I then drilled a 1/4" hole dead center in the board, and from the bottom up, placed a 1/4-20 bolt long enough to reach through three boards and still have enough length to put on a nut. At this point I was ready to route out my mold, but required two items. One was a circle jig. (you can buy these, but I just made my own from some 1/4" luan plywood) The other item was a tapered router bit, which allows easier extraction of your stator from the mold. A straight vertical raised-panel bit works perfectly.
    I set my circle jig to route out the inner diameter edge, and began to plunge cut the bit until it was as deep as the coil thickness. I cut all the way around, then did the same for the outer diameter. (in my case, my coils were a little thicker than the boards, so I ended up routing out a bit more in the lid. Don't do this, instead route deeper into the bottom board if need be. You'll have less problems with trapped air later)
    What not to do: (domed lid)
    I finished up by drilling a 1/4" hole dead center in the top board, and also drilling holes where I want the power output lugs (the brass toilet bolts) to go, and coating the inside of the mold with mold release wax.
    Next episode, finishing up the stator.
  2. #162
    14,485
    Hey Rod, If that stator mold has got ya worried, I have a fungus nut who can identify it for you. Ha ha.
  3. #163
    LHN, your fungus is talking now? JK... Rod, great to see that the thread is back up and running!
  4. #164
    Ha, well, since this thread has become active again, I may as well share some of the progress I've been making. So here's some pics of the alternator construction.
    Stator layout with magnet placement visualization. You can see I've been playing with different coil shapes. I've changed my mind at least three times already, including once today!
    Magnets glued onto rotors, and template for setting magnets. At this point, the rotors are VERY dangerous to handle. Each magnet by itself has 87 lbs. of pull, together it's 1044 lbs, and with the flux conductance of the rotor, it's even higher to a value I'm unable to determine, but it could be as high as double, and that's only one rotor!!!! Needless to say, if you got your fingers between the rotor and some heavy steel, or the other rotor, you can kiss them fingers goodbye. It would squeeze them clean off!!!! :shock: :shock: :shock: :shock:
    And this is cutting the mold that will make up the stator drawn in the first picture. You can see the hub assembly laying in the background.
    That's about where I'm at. More to come.
    Rod, why is one coil shaped differently on the bottom right?
  5. #165
    Actually the two bottom ones are drawn differently. I was experimenting with different shapes to see if I could find any advantages, but stuck with how the majority were drawn.
  6. #166
    Peter, your PM inbox is full. I believe these are the magnets I ordered: http://www.magnet4less.com/product_i...roducts_id=162
  1. wind power II & a few random thoughts
    By rocklock in forum Solar energy and alternative power
    Last Post: 01-30-2010, 09:48 PM
  2. WIND POWER !!!!
    By Tatius in forum Solar energy and alternative power
    Last Post: 12-21-2007, 12:04 PM
  3. Maglev Wind Turbine Power Plant
    By ponyboy in forum Solar energy and alternative power
    Last Post: 07-30-2007, 12:38 PM
