Originally Posted by
erisso
THANKS AGAIN,
Well to bad i call little late and the guy sold the 4 other battery's for 50$ peace
ok now i will do the testing as soon as find electrolyte and battery pack is mounted
ill be starting 12v as i have a 3000w/6000w 110v converter sitting here
as for wires i have 10 feet from bank to converter
Turbine is already 40 feet up in the air ( it cant turn I locked it)
and wired with 60 feet of #6 to were ill be placing my battery bank
Idd appreciate if you could take a look at my idea of battery configuration in fallowing link
http://i242.photobucket.com/albums/ff283/erisso/configuration2.jpg http://i242.photobucket.com/albums/ff283/erisso/CONfiguration.jpg
as i cant add battery to my bank
i thot of adding a bank that would help in 2 ways,
absorbing extra watt that my bank cant take from turbine and giving me extra storage without changing all batterys
both are showing 12v but as said any of them could be converted to 24v easily as both banks are independent.
im maybe off route so any comment is appreciated
In your "On a side note" you mention "I'd been forced to get a second charge controller "
I know from an other post that you intend to install a 3 phase turbine,
is this "charge controller" the same as "battery dump regulator" or an other thing thats required for
your installation or for all installations,
(please understand that im French speaking and some times same thing with 2 names gets me confused)
an addition
if my batterys are 12v for 8 cells this is 1.5V each
if im putting 2 extra cell to the line adding 3V to it for total of 15V per line
will not that drive my inverter crazy as it has hi/low protection
Eric
