Page 302 of 302 FirstFirst ... 202252292300301302
Results 3,011 to 3,019 of 3019
Thread: Introduce yourself
  1. #3011
    loghousenut,
    We just signed up for the class, last weekend. With all that's going on (and my wife's crazy work schedule), haven't had time to start it yet, but hopefully will do so, within the next week. Looking forward to that, too!
    Going down to the property tomorrow and Saturday to enjoy some beautiful spring weather (finally!) and get started on more projects. May do a little logging - limbing and cutting up downed trees - not felling them. But that may be in the future.
    Aaron
  2. #3012
    Rick,
    Really nice place you've built for your family up in Okanogan, real nice. I'm sure they enjoy it a lot. I think that's about the best I've seen a shipping container look (no offense to those building actual residences from them)! We're in your area often, as Olympia is about halfway between our current house and future log home, plus my Mom also lives in Olympia.
  3. #3013
    LHBA Member DoubleJRanch's Avatar
    Mar 2020
    Olympia WA
    209
    Quote Originally Posted by mudflap View Post
    Yeah, it's got the 3.0. Researching it, I think I had the problem where the back cylinder next to the crossover pipe gets too hot- my valves burned up in that cylinder. I bought a new motor off ebay and plugged it in. And re-routed that pipe down away from that cylinder.
    Sent from my SM-G530T using Tapatalk
    Ok, you have the early 95, pre Tacoma, ie VZN110L model (door jamb sticker) Probably the R150F 5 spd, 4:30 axle ratio... I cut my teeth on these. A tech during the headgasket recall era, I got that down to 3.5 hours.
    No, burnt vales are just usually not enough clearance. They are shims and so they get neglected. Measure them stone cold, you will find intakes will all be fine, exhaust can get snug. If too tight, the valve doesnt fully seat, but still runs good, and by not fully seating, its unable to get rid of the heat in the valve top. For that small time its close, its losing heat to the head. Usually about 150K to 200K on an engine that has had its oil always changed ie no abnormal wear. The normal wear is to get tight. Abnormal is to get looser.
    Shims only get so thin in size too, I have seen where the smallest shim made is still too tight. Means valve has burrowed it way too deep and no shims made. They get too thin, they will kick out or be lower than the bucket. I have access to factory manuals, I can send you a nice chart to aid in picking the right shims too.
  4. #3014
    Mar 2020
    Olympia WA
    209
    Quote Originally Posted by aaroncgi View Post
    Rick,
    Small world Aaron, isnt it. Hey. that container is just a quick look at my style. I am super picky about everything I do.
    Aaron, I am here to tell you. Oregon gets lots of fires in the summer, especially eastern Oregon. As someone who almost lost it all twice during one fire, give yourself enough space between vegetation and home, gravel doesnt burn and baffles on gable vents, hardi soffit for under eaves, metal roof, all trim angled to shed blowing spark, no firewood on or under porch etc. Dont rule out plumbing under eaves with small holes drilled into it to turn water on to wet eaves in the event a fire does come your way. I always wanted a cabin nestled under the trees, till the fires came, got an emergency group of friends, took emergency time off work, we went into the gates of hell, smoke so thick, you could cut it with a knife. No living things seen except aggressive yellow jackets and aggressive flies biting at dry skin on my elbows. I cut way back, then next spring, in came load after load of gravel.
    My truck smelled of smoke for several months and forest fire doesnt have that nice campground wood smoke, it stinks, its different.
  5. #3015
    Rick,
    Yes, both Oregon and Washington have had lots of big fires in recent years. That's all good advice about house design and vegetation placement. Our house will be sitting in the middle of a three acre clearing. We'll plant many new trees and shrubs as we see fit, but all keeping in mind maintenance, access, and fire protection. We're definitely using a metal roof; it just makes the most sense to us, for many more ways than fire safety. A cabin nestled under the trees is a beautiful thing, and usually, we don't have to worry about fires on our side of the mountains. But, the summers (2019 excepted) do seem to be getting hotter and dryer. We can always make a tiny little cabin in the woods, that isn't our primary residence.
  6. #3016
    Hello from AK,
    Just finished the online course in record time. Great information and well presented. Thank you for opportunity. Were looking to start building in a year or so. Well have an unobstructed view of Cook Inlet and 5 volcanoes from our great room so we have to match the majesty by building a log home with the biggest logs we can find and afford. Im all about DIY so this construction method is a perfect fit. Thanks again.
  7. #3017
    11,925
    Welcome aboard Mr. Fire. I also just took the course... from Skip in 1981. You'll like it here.
    Sent from my Pixel 3a XL using Tapatalk
  8. #3018
    Hello from Toronto! Google took me here. Thought I would stop being a lurker and join the community. Thanks for letting me in. See you all around soon.
  1. Introduce yourself
    By Woodman in forum General discussion about log homes and cabins
    Last Post: 03-11-2014, 12:38 PM
  2. I am new to this virtual community and would like to introduce myself.
    By rlrasi in forum General discussion about log homes and cabins
    Last Post: 01-09-2008, 11:45 AM
  3. let myself introduce myself
    By ChainsawGrandpa in forum General discussion about log homes and cabins
    Last Post: 06-04-2005, 11:07 AM
