Recently bought a log home. I'm looking for some ideas to trim where the logs contacts a flat surface. Any ideas help. Images Below with description.
Ceiling to log connection (foam bleeding through the gap)
https://imgur.com/a/HjK2N1R
Ceiling to log connection (Foam bleeding through gap again)
https://imgur.com/a/raq1FRO
Exterior trim above door large gap between log narrow area and trim board. Bat and bees often find homes here.
https://imgur.com/a/oLrSQIm
Same trim as above.
https://imgur.com/a/5J0ACe0
Log to floor connection. Tile doesn't sit flush and trowel lines are visible. need trim ides.
https://imgur.com/a/9Kq1A98
interior shiplap wall connection at a 90* angle with logs. the gaps are filled with foam but uncovered. Need trim ideas here.
https://imgur.com/a/4ohhm9r
Ceiling to log connection. This is a small example. Most are butt jointed and not a good connection.
https://imgur.com/a/656Twle
