Results 1 to 5 of 5
Thread: Nee dsome advice on movement
    Hello All,
    Been a while since I posted, and I hope you are all well and safe.
    I have a question with regards to movement of my logs in my home.
    For some background, the home I am in was built 23 years ago, and I have only been in here a couple of years. The original doors and windows are Aluminium, and I am replacing with new timber. The question I have is, how much movement would I expect now, after 20 years. I can't use the same technique to attach the new windows and doors, as the method won't suit timber (was Alu) and so am looking for ideas.
    Is it a bad idea to simple attach the new doors and windows to the logs, now that they are so old?
    Thanks all,
    John
    3,094
    55
    I would build a frame and install it in the logs first, and then put the doors and windows in the frame.
    probably depends on what you mean by log movement - is it a kit home or does it have raw logs?
    diaspora: https://sysad.org/people/f18c3df0447...dd1eac510f7330
    bastyon: https://bastyon.com/tailgate
    LHBA Member slamasha's Avatar
    Feb 2005
    Sno county WA
    1,133
    Agree with mudflap.
    Sent from my Pixel 4a using Tapatalk
    LHBA build is a process. Accept it'll take some time, will be more expensive than you thought and enjoy the journey.
    Thanks Guys.
    Not sure what you mean by raw logs. As mentioned, it was built a while ago. All logs are treated inside and out etc.
    Definitely not some kit they bought. It was custom built.
    I am not sure how to upload an image or I could show you.
