Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Chinking material in Australia
    12,800
    That appears to be 1/4" or less and caulk should do nicely. Chinking is for the 1 to 5 inch gaps (OK 7") that we LHBA members get to play with.
    That Imgur site is great for photos but next time try the BB Code link. It comes to us bigger and better.
    Sent from my LGL83BL using Tapatalk
    Yeah thanks. I think the Caulking material is going to be my only hope!
    12,800
    I would much prefer caulking that place with a cheap air powered caulk gun than chinking. The cheap Harbor Freight air caulking gun works just fine.
    10,849
    Surprised to see those gaps, honestly. I wonder if the logs have been pinned as well?
    LHBA Member mudflap's Avatar
    Nov 2015
    North Alabama
    2,999
    53
    John, that is a complete different animal from the way we build here. Your style of log building is called scribed and coped. The logs are carved so that gravity makes them fit tightly together, requiring no chinking. In fact it is called chinkless on purpose.
    As you have noticed, the wind still comes in and out wherever it wants to as the logs settle and twist. The common cure is to caulk the seams.
    Go to Permachink or Sashco and nose around looking for videos that show your problem and their cure. They both put out a top product at a top price but you can afford it.
    Tons of colors and they will send samples. Some folks like to match the log color and some folks like to contrast.
    One last thing. If it is time to restain, you should probably do that first.
    PS... Congratulations on your new place. If you outgrow it, consider building your own like we do it here. It is a blast!
    I sure love it when LHN posts pics. ahhh.......
    blog: https://loghomejourney.wordpress.com
    diaspora: https://sysad.org/people/f18c3df0447...dd1eac510f7330
    12,800
    Thank you Mudflap, and you are welcome...
    Nov 2015
    North Alabama
    2,999
    53
    If you're trying to get me to take it back, it won't work. ...
    Sent from my SM-G530T using Tapatalk
    3,653
    Stuck inside a lighthouse?
    Sent from my SM-G960U using Tapatalk
    10,849
    There are far worse places to be stuck. LA immediately comes to mind.
  10. #20
    If you mean pinned, as in, bolted in place, then yes. That top log is a dress log only!! It gives no structural benefit. Behind it are basically poles that are bolted to the next log down that is used to support the roof.
    Some of the gaps are large - maybe 1. 1.5 inches!!
