Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
    10,210
    It should work, but it will increase heat significantly, likely shortening lifespan.
    So I'm researching solar diy kits again. I'd like to put them on my roof. But I'm concerned about the wiring. Like how exactly do you may the connections? What kind of wire stubs are on each panel?? How do you wire it back together before going to the panel.
    I can't find any info online all they talk about is wiring in parallel or in series.... I don't care about that
    10,210
    I've seen a couple different ways panels come. Some with a screw or threaded post and nut, but mostly with a pair of 3~4 foot wires stubbed out of a junction on the back, with MC3 (old type) or MC4 connectors on the ends. The connectors can be cut off if you wish, and use weather tight connectors directly into junction boxes, but better to buy the associated MC3 or MX4 pigtails and wire those into a junction box or electrical trough. Then you can change out panels quickly by just unplugging the MC connectors
    Ok, so each panel connects to a fairly idiot proof connection. And at some point all those wire go to a junction box where it then goes to the panel and backfeeds or is used etc.
    Would you say that if I built my own house and wired at least half of it myself, it would be fairly easy to do?
    11,142
    Any fool of our caliber can do it. Get a look at Home Power online magazine and you'll get a handle on it.
    10,210
    Give me more info Throner. Grid-tied or off-grid (battery bank)? If off grid or hybrid, bank voltage? Panels voltage? MPPT or PWM type charge controller? Housed wired for AC, or both AC and DC?
    I would do grid tied.
    2,232
    48
    I'll watch this thread later on, but....
    We wanted to orient the house so the angle for solar panels would be correct, but no matter what we did, it looked weird to us oriented that way towards the road. So, the plan is to have the garage roof face that direction instead. it'll probably work out better for accessing the panels anyway, since the garage will only be 1 story. Also (and the boss doesn't quite know this).... ima have a huge water tank in the attic of the garage, already piped and ready to feed the house as a gravity system- just a little valve inside the house to activate it. Sure, it won't feed the upstairs bathrooms in the house, but at least we'll have running water to the main level.
    diaspora: https://diasp.org/i/bcd179c35cd5
    3,451
    I oriented my house for the max sun exposure on the Southern roof. It was either facing 175 degrees or 185 degrees, I forget which.
    Since Iím in the middle of 80 acres of trees, any direction would look the same.
    Sent from my iPad using Tapatalk Pro
