That's a great way to go, and I thought of using glulams for the purlins - can even put a bevel on the top to match the roof pitch. Our issue is that our second floor plan is almost completely open, so no walls in which to support the purlins.
I actually thought of a kind of crazy way to support PSLs, using a log girder spanning across the center of the house, on top of and perpendicular to our second floor girder (ie the same plane and direction as the second floor joists. The PSLs would then rest of top of the these logs, halfway between the eaves and center. Naturally, the second floor girder would need to be significantly enlarged, and the corresponding posts... No idea if this would have worked or not, but it looked and sounded cool in my head!
