Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: building a 10X10 hunting cabin
    I am very new to this so please forgive the silly questions. I've watched a lot of youtube videos and am not quite sure what to do at this point.
    I was originally going to try the butt and pass method and using rebar to hold it all together. With my electric drill i'd drill a pilot hole and then drive the the 1/2" rebar down through the two logs to hold them in place. Repeat every three feet or so. The pieces of rebar would be 16". Is that going to be to difficult to accomplish you think?
    The other option was to notch out the logs. If I used this method, my question is do both sides of each log get notched at the end? In the half moon/cup fashion? I would assume both sides of the end of each log got notched so that way the main length of the log would rest on the log above or below it, minimizing gaps....correct?
    10,576
    First question, you should be fine. And watch this for the second question: http://youtu.be/3YzalwBcPck?t=21s
    2,525
    1 the class recommends spacing, etc.
    2 you aren't doing "butt and pass" if you're notching at all.
    Take the class, you'll be glad you did.
    Sent from my Galaxy S4 using Forum Runner
    I guess I wasn't making my notches deep enough? I've seen Dick P's video before just never really realized how deep he notched his logs. My wife was trying to tell me when I was practicing the other day that I needed to notch BOTH the top and bottom of the log. I disagreed. Dick just notches the bottom of each log. Now if I can just make my notches square with each other i'll be in business lol
    10,576
    Your wife has seen too many Lincoln Log toy sets.
    Pennsylvania
    179
    #2, i think you'd want the half moon on the bottom so water would run off better.
    Mike
    Pennsylvania
    2,525
    Quote Originally Posted by StressMan79 View Post
    2,236
    Quote Originally Posted by Mitchell View Post
    Don't try notching your logs, you will not be that skilful until you have notched one hundred... I built a 10 by 12 shed to protect my well. My only suggestion is to look at the student built homes. There are quite a few that show construction. Do not scrimp on the steel or the foundation. Insure your roof overhang is twice as big as you think it should be. Good luck.
    You mention a class. I'm new here and wondering what class you are referring to? Thanks!
    12,115
    Quote Originally Posted by srowson77 View Post
    The world renown, 2 day log homebuilding class at http://www.buildloghomes.org/
    Take the two day class and you will become a lifetime member in the Log Home Builders Association (LHBA). Once you have taken the class you will gain access to the "members only" side of this forum and that's where the real fun begins.
    I took the class in 1981 and have been loving it ever since.
    PS... Don't take the class unless you are serious about building your own log home with your own two hands.
