Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: I d
    2,518
    i don't know if this is even feasible
    http://www.foxnews.com/politics/2014...w-wood-stoves/
    Dunno how you can heat a home emitting only 1.3g/hr...
    Poolesville, MD, building in WV
    1,259
    Going around hurdles
    Quote Originally Posted by StressMan79 View Post
    Lots of little stoves? ;-)
    11,478
    Beginning of the end.
    LHBA Member logguy's Avatar
    Sep 2009
    MidMo
    386
    6
    WTF (Way of The Future).
    I guess I won't be going into mass production of the barrel furnace kit I just put together for test cabin #1. Maybe I could scale-down the design to double-barrel soup-can sized furnaces hooked in series.
    Every man dies. Not every man really lives.
    William Wallace
    Everything in life is luck.
    Donald Trump
    If your goal is wealth, you will die a poor man.
    LHBA Member jrdavis's Avatar
    CB, Iowa
    1,078
    Maybe like this..... :+)
    http://www.whydontyoutrythis.com/2013/11/how-to-easily-heat-your-home-using-flower-pots-an d-tea-lights.html?m=1
    flower pot heating.
    10,345
    Yay! Black market stoves, here we come!!!
    Sep 2009
    MidMo
    386
    6
    That is very cool.
    Our sheep, rabbits, chickens and dog survived shut up in the barn over the last few days--but only due to our constant attention during the sub-zero temps here. Anyone got any old-school (or new-school) ideas on how to keep a barn above 32 degrees so water doesn't freeze? With hay in the loft, I'm uncomfortable with every form of heating device I've come across--and the florescent light we have in there even makes me uncomfortable. If I was at this farming thing full time, I'd try a trench right through the middle of the barn with 50' of concrete blocks buried side-by-side (holes facing each other) about a foot deep and have a fire going on one end of the blocks (20' away from the barn) during these below zero days--the gasifier concept. But no time for breaking the code on stuff like this, though. Ideas?
    William Wallace
    Donald Trump
    10,345
    Either air-to-air or fluid-to-air heat exchanger. Plenty of options, where you could remotely have a boiler outside or in a secure room, or a sealed gas/oil fired exchanger heater. (gas style is usually exhausted through pvc pipe, to give you some idea how cool the exhaust temps are)
    Sep 2009
    MidMo
    386
    6
    I forgot a few parameters: cheap, easy to maintain, low tech, easy to install...cheap...
    William Wallace
    Donald Trump
    10,345
    I think you're asking for the impossible, but Google 'hazardous location heater' and 'explosion proof heater' and see if you can find something to fit your bill.
