I just found 20 ft angle iron 4" X 4" X 1/4" locally for $76 each.
Thats a steel.
so now I don't have to weld on anything for mine.
Once the deep freeze gives up, I'll be able to level and switch my HF mill over to the new track and be back in business.
21inches is about the MAX cant I can cut.
I have chainsawed some bigger logs with curves to get a 3 sided beast I can cut slabs on.
everythign I've cut has been waste wood or windfalls, so i don't care AS MUCH about the waste, but I hvae recut a few of the waste ends.
JD
