Results 1 to 10 of 12
Thread: Sanding and Staining...
    I haven't been able to take the class yet, but plan to in the fall. One thing I wonder about as I read through different blogs is why the logs aren't sanded (and possibly stained) before they are stacked...especially the sanding. Is it because they aren't actually sanded, but instead are just pressure washed?
    Thanks for your input,
    Lisa
    10,960
    Several answers, Lisa, but the main reason is that using the system taught at LHBA class, we can stack green logs without the traditional worries about log wall settling issues. Most stains wouldn't like sappy logs and sanding would be a disaster. Also the logs would get ugly as you dragged them to the building site, etc.
    So you peel your logs. Then stack them. Then get them under a roof. Then the big rush is off and you can relax and finish your log home as your logs are curing.
    Canada... eh.
    1,709
    Not to mention you are going to cut a bunch of holes in your logs for windows and doors and you probably don't want the same stain on the outside as on the inside (if you want stain inside at all).
    This makes sense. All of it. Simplicity just about sums it up.
    10,960
    Quote Originally Posted by LBolton2008 View Post
    We're just scratching the surface, Lisa... You oughta hurry up and snag a seat in the next class.
    LHBA Member blane's Avatar
    Apr 2008
    Clyde, NC
    1,807
    My two cents worth... NEVER sand logs. Stacked or not I will never do it again
    10,960
    I sure wish we could get Fuzzy to say that. It'd be the word of a bonafide expert in the subject..
    Sent from my ZTE V768 using Tapatalk 2
    Blane,
    What would you recommend doing? The loggers weren't as gentle as I would have hoped when they were unloading, so we have some rough spots that I had intended on sanding smooth, but hearing someone say "I'll never....." Always makes me think twice if that's what I was going to do.
    Canada... eh.
    1,709
    Sorry Nut, I'll still do it on the next one... ok, maybe I'll get smart and walnut/cob blast.
    Walnut shells. Sanding logs is NUTS!
