Pole barn for logs: questions
I know this is really not the place for this but I am going to build a pole barn first to store my logs in for the house, as well as equipment, which will be used as a shop later. If anyone has done this here already maybe you can help. I plan on the size of 32 x 50. That way if I put a door on each end with a couple doors on one side I can pull the logs in with the tractor, drop them, out the other gable end and then come at them from the side to stack them. Does this sound like a good plan?
Also, a quick question on the poles: would it be better to drop the poles in past the frost line or build a pier and attach a bracket on top for the poles? To me it sounds weaker to have the bracket but the thought of wood in the ground , even though treated, is not good either. Thanks for any input.
