Best was to make a "slot cut"
I am close to finishing rough framed interior walls, and even though plumbing is not started, I am starting to plan for the finishing of these interior walls (shiplap panels). I understand these should be cut to mimic the curvature of my 10" logs where the panels meet the exterior walls, then accept future board shrinkage and address that with caulk. OR, a "slot cut" can be made into the logs, a cut 3/4" wide and 1/2 inch deep. Then the board slides into this slot, and when it shrinks the shrinkage is not noticeable, it still appears snug to the log curvature and looks tight.
1) what is the best way to make this slot cut? Skill saw? Router? Multi tool? Then use a 3/4" chisel? I am interested in the most in control method that doesn't take forever... Do you put down a guide board to help hold the line? How do you create this slot cut in the hard to reach portion of the curvature, where the two logs meet? The world wide web has no videos I can find on this.
2) what is the best way to cut the shiplap board end with the proper arc so it mimics the log curvature. I can certainly create a template for marking, but then do people just use a jigsaw? Is there a different tool? My jigsaw lines always have more wobble than I like.
Thank you very much for any comments!
