It took you a entire week? You must be gettin' old.
Nice pics!!!!
Love seeing the insides!!
You can check updates at my Imgur profile. I guess I'm maxed out of embedded forum pics.
Ronnie, how tall are the walls to the cap log, and also how much wall will the owner end up with on the loft area? I'm doing a 30x30 and was curious what I was looking at dimensionally.
I also noticed a two piece cap log on there. Can you help me understand what's going on there?
Walls are around 13', loft will have 3-4' side walls. Load bearing logs had to be stamped, only one of the long logs met the grade criteria, so we had 4 shorter logs stamped and did 2 piece cap logs
Hey Ronnie,
Do you have any pictures of you setting RPSLs on any of your builds? I plan to frame and deck the 1st floor before setting logs, but just started thinking that those floor joists @16" OC are gonna make for a tight fit. Any secrets, or am I over thinking it?
Well, my concrete RPSL columns didn't jive with the 16" OC for my TJI joists, so I left one out in the middle. I'll probably end up mounting them to the RPSL somehow.
Visit my Imgur acct for a pic of the RSPL install.
Pour your concrete columns to the subfloor level
